BIG PARTS LIST, Bought 3 more Parts cars, and did some Spring cleaning. Tons added!
Intercooled88s
Moderator
The New parts cars are a 86 T-type(silver with blue bench), 85 T-type(Black with gray bucket) and a 85 T-type(White with Maroon buckets)
-Turbo crank(Std/Std but will need to be turned at most .010/.010) $250
-Connecting Front brace- That goes under the radiator support $35(1986 1987 Buick Regal Grand National Turbo T T-Type GNX CONNECTING FRONT BRACE #6756).
-Front braces- That go under the car from cross member to frame $35(1978-1984 1985 1986 1987 Buick Regal Grand National Turbo T T-Type GNX FRONT FRAME BRACES (2) #6564)
-South side machine lower control arms(rear Lift bars)(In like New condition) $70
-Pro Comp Speedometer- make offer
-Pro Comp electric Water temp gauge- make offer
-Pro Comp electric oil pressure gauge- make offer
-Pro Comp fuel pressure gauge- make offer
-Pro Comp boost gauge- make offer
-Auto gauge 5 inch Tach with shift light- make offer
-Digital dash $200
-NEW Felpro gaskets(2 head gaskets 8723pt-1, 2 cork valve cover gaskets,2 Exhaust manifold gaskets) $35
-86-87 Alum Alt pulley $20
-84-85 Flex cooling fan $10
-Green Strip inj $100
-85 Power steering pump(For car with power master) $30
-Used Alum Rad $75 No engine or trans oil cooling)
-New in the box Griffin aluminum radiator(NO engine or trans oil cooling) $110
- trans cooler $20
-Nice set(drivers and passengers) of rewelded 84-85 exh manifolds $100
-Passenger side Front bumper filler $50
-Drivers side rear bumper filler $75
-Drivers side rear bumper filler(black) $80
-Passenger side front bumper filler $50
-Header panel(GM) $130
-B body spindles $50 for pair
-85 Maroon bucket seats $150
-Maroon steering wheel in drivers condition, no center cap or ring $35
-Maroon shifter handle $25
-Blue shifter handle $25
-BQ transmission core(unknown condition) $100
-Crank window regulators $50 for both doors
-Dash vents(with nice chrome) $20 each
-Chrome strip(above glove box, in nice condition) $30
-Nice Gray card board and cloth inserts(under quarter windows) From 85 T-type $30 for both
-Gray dash pad with a small hole drilled at the lower right of the drivers seat(Its not even noticable) $75
-Visors good for cores(non mirror) $20 a set
-84-86 power seat track assembly $100
-Chrome marker light $35 each
-Passenger rear wheel well trim(needs to be repainted) $100
-Both tront head light bezels(need to be painted) $70 for both
-85 Power seat track $120
-Rear center filler(The part that the rear license plate bracket attaches to) $30
-Pass remote mirror bracket(Just the bracket that attaches to the dash) $15
-NOS black plastic seat track cover for rear right side(GM part # 20023766) $20
-Front fenders with GNX style louvers installed $200 for both sides
-Frame in good condition $200
-heater box shield $10
-84-85 Shield to cover heat hoses $15
-bumperette rubber strips in good condition(used GM not after market) $20 each
-Stock factory lighter $8
-Stock Battery hold down $10
-85 gray bucket seats $250
- gray console $150
-Gray T handle for shifter $30 shipped
- Rebuilt 85 long block (10k miles) .030 Forged pistons, .010/010 crank $900
-Connecting Front Brace $25
-Front frame braces(underside) $25
- 86-87 MASS AIR FLOW SENSOR BRACKET $5
- 84 GN drivers side upper door panel good condition(but no chrome strips) $40
-Syclone (air/liquid) intercooler modified with 3 inch inlet and out let $125
-Plastic Brackets to mount front air dam $30 for 2(For both sides)
-Good hood shocks $10
-Stock turbo inlet bell $20
-009 injectors $150
-86-87 engine hoist bracket(on intake) $20
-Vac brake set up with New(Reman.) B body Master cylinder(master cylinder, vac asist and gbody pedal) $140
-New ARP Rod bolts 123-6002 $60
-New Felpro Valve cover gaskets(Perma Felpro) VS50156T $10
-GN driveshaft $50
BRF transmission $500
BQ transmission $250
87 gray cloth Limited front and rear seats $200
87 gray column (shift on column) $100
87 Split bench seat power seat track assembly $100
85 turbo Riviera std block $200
109 turbo block .060 over $100
85 Turbo block bored .030, never used since machined $200
87 Rebuilt 109 long block less then 1000 miles on it (Postons cam- 212 Int/206 Exh)(block .030 , .010/.010 crank) $1500
87 GN long block(around 100k) $800
Original GN fender extensions for car with spoiler
Maroon console $150
84 GN console $150
87 GN console $150
-84 Red upper door panels $80 minus chrome/gray strips $50
-Grey T-type upper door panels no chrome strips $50
-87 Maroon upper door panels $50
Drivers side Blackout head light bezel $40
Chrome head light bezels painted black $40 for both
Marker lights $40 each
Blackout wheel well moldings $60 each
Chrome(Regal) wheel well trim moldings $45 each
84-87 T-type header panel with hole filled $150
84-87 T-type GM header panel, has some small imperfections $125
84-87 Grand National GM header panel, has imperfections $125
Passenger remote mirror(needs paint) $60
87 GN seat belt set(10 pieces) $120
84 GN steering column $150
86 Blue steering column with tilt/cruise $150
Maroon steering column with tilt/cruise $150
87 GN grey column with tilt/cruise $150
87 grey coumn(shifter on the column) $100
84 Gold bucket seats $250 with rear seats $300
86 nice blue 86 442 bucket seats $150
Gray Monte SS seats $150
Maroon bucket seats need recovering $100
85-87 GN bucket seats need recovering $150
86-87 GN console $150
84-87 Consoles I am using for parts, e mail me with specific pieces
Shifter without T handle $25
shifter with blue T handle $50
85-87 Gray concert sound lower door panels $100
Concert sound door speakers with mounting brackets and wire harness $75
GN Dash Plaque $75
84-86 T-type dash plaque $50
86-87 Upper intake(dog house) $30
86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
86-87 bare throttlebody $40
86-87 Up pipe $25
86-87 Cruise control assembly $35
86-87 Water pump pulley $25
86-87 Crank pulley $45
86-87 Main accessory bracket $70
86-87 Y bracket on back of Alt $35
86-87 Flat Y bracket on front of AC compressor $35
86-87 Intercooler brackets $40
86-87 Coil brackets $40
86-87 Power steering res. bracket $20
86-87 Power steering pump $70
87 GN Electric fan $50
84 rad shroud $30
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
86-87 T-type wheels $100 each
87 locking t-tops $150
84-85 Non key locking t-tops $100
Astro roof complete assembly with wire harness, switch etc. $200 wont ship
Astroroof parts, I have the whole set up but the glass is scratched up, E mail with needs
Bigger then stock front sway bar $70
Fuel sender/fuel hanger(analog gauge) $80
87 BRF tranny $500
BQ tranny $250
Rebuilt BQ tranny $400
D-5 convert $50
Hot Air to Intercooled Conversion: Includes parts to convert from 84/85 to 86/87 Intercooled
setup. $1700
ENGINE PARTS:
AC compressor(84-85) $40
AC compressor(86-87) $80
AC lines(84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $35
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover)
$20
Block(109 Block) $300
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Coil pack(84-85) $40
Coil pack(86-87) $25
Control module(84-85) $50
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(84-85 ECM) $40
EGR plastic cover $5
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $35
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $40
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(metal, frame mounts) $35
Oil pan(Turbo oil pan) $40 each
Power steering pump(86-87) $70
Pulley(86-87 Crank pulley with adapter) $40
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Rock arms+shafts(stock, complete set) $35
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody bare) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers (84-85) $30
Vapor cannister $10
Wire harness(84-85 engine wire harness) $150
INTERIOR:
I have every color interior parts except Green.
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound speaker covers(84 GN) $50
Console shifter plate(Plate on console that goes around the shifter)$25
Dash pad no cracks(grey or Maroon) $120
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $80
Radio(Stock GN radio with cass, no EQ) $40
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $150
Shifter $35(84-87 GN, needs T handle)
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red, Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue $20 for each
piece
Visor(Nice blue passenger visor with lighted mirror) $20
Body Parts:
Blackout trim for front windshield $20 each piece or $50 for all 3
Blackout trim for rear window $20 each piece or $50 for all 3
Blackout trim around the door windows $20 each piece
Blackout Drip rails(hard top) $40 for both
Blackout(Trunk Lid blackout trim piece) $35
Blackout trim, T-top boot shaped trim that the T-tops lay on $60 for both
Blackout trim, T-top center trim piece, that the t-tops slide into $70
Bumper(GN Rear black bumper) $100
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Front bumper shocks $25 for both
Rear bumper shocks $25 for both
Fenders(84-87 GN fenders(GM)) $100 each
Grill 87 GN Grill $200
Grill 87 Chrome grill painted black $125
Grill 86 T-type grill $50
Grill 85 GN grill $60
Grill emblem(87 , says "Buick") $15
Hood(GN hood) $150-$250 (pick up only)
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Lock set(all 3 locks with key) $50
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror,non remote)$20
Mirror(Passenger Mirror, Remote) $65
Quarter windows with blackout trim $80 for both sides
Tail lights with blackout trim $90
tail lights with chrome trim $70
Wheel well(Drivers Turbo plastic wheel well) $80 each
Wheel well(Passenger Turbo plastic wheel well) $100 each
Any other blackout piece e mail me I have them all
Misc:
Antenna( black manual antenna complete with mast, base and nut)$60
Antenna base nut and spacer for Power antenna with black trim $10
Control arms(Front lower)$60
Control arms(Front upper)$30
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Heater box shield $15
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
86/87 Tranny dip stick and tube $45
Transmission oil pan(Stock 200 4r tranny pan) $25
(2)Billet wheel adaptors 1/2 Make offer
84-85 T-type wheels $40 each or 4 for $120
84-85 GN wheels $100 each (no center caps) or 4 for $300
GNX Style 16 inch Wheels(Western wheels) $350
windshield wiper assembly $15
E mail Fortune628@aol.com or PM me.(Best way to contact me.)
Cell number is 413 563 8819(I do NOT check voice mail on this number EVER.)
Im looking for the following. If you can give me a price:
-Good set of Door escucheons (chrome strips pull strap connects to)
-86/87 MAF
-B Pillar Trim for the Interior (any color)
Znix
Hi,
Do you have a "Blackout wheel well molding" for the rear drivers side?
If yes, can you tell me how much for shipping to 60543. Thanks!
Chris
-Digital dash $200
- trans cooler $20
- gray console $150
-009 injectors $150
-GN driveshaft $50
Maroon console $150
84 GN console $150
87 GN console $150
GN Dash Plaque $75
86-87 Up pipe $25
84 rad shroud $30
87 BRF tranny $500
BQ tranny $250
D-5 convert $50
setup. $1700
ENGINE PARTS:
AC lines(84-85) $40
Alt.(86-87) $60
Alt.(84-85) $30
$20
ECM(84-85 ECM) $40
Intercooler $45
MAF(84-85 MAF) $40
Timing cover $35
Vapor cannister $10
INTERIOR:
piece
Body Parts:
Misc:
wanting to know do you still have 10pc seat belt set, i want to purchase them.
Just did some thinking, and had an option pop into mind...
Might have an interest in working a deal for the gnx flared fenders & digi dash, amongst other things depending if my brainchild works out... try calling me sometime, or if I remember I'll give you a call from ATL at some point...
-86/87 MAF
Znix
I dont have the 86/87 MAF, I have the door escucheons, but I'll will have to check and see if I have all 4. I just sold a set and Im not sure I have all of them. Is there any prefered color on the B pillar trim?
Hey bob, I need a passenger side front bumper filler,iac housing, tv cable, gnx fender flares in mass tried calling you and left message yesterday about a couple of car I have for parts....joel
Pm me your number and I'll call you. I have the passenger front bumper filler, iac housing(I'm assuming for 86-87) and TV cable. I think the GNX flares are sold.
I'll call you tomorrow night.
