SignUp Now!I paid you for the GN spoiler on 10/16 just wondering when its going to be shipped.
I want the "Pulleys(86-87 underdrive pulleys(crank and alt)) for $35
Sending PM now...
K.
Bob
Waiting for your address so i can send payment for the 87 a/c lines and battery cable guide if you tell me the total for the turbo inner fenders with shipping u can ship all togather
Gene
I want the black headlight bezels and both black side markers,How aboutI have a New e mail address, it Fortune628@wildblue.net .
6-87 T-type wheels $100 each
86-87 GN wheels $125 each
Set of black rear bumper fillers in good condition $150
New fiberglass front bumper $110
NEW after market header panel $80
87 GN grill $150
86-87 GN wheel center caps $10 each
Vacuum brake set up(master,vac assist and pedal) $65
Digital dash works fine $150
87 GN complete engine oil pan to throttlebody, MAF to ECM, runs good $2500
84-85 stock turbo $150
87 BRF tranny $500
8.5 Posi rear 3.42 complete drum to drum with driveshaft $800
8.5 Non Posi rearend 3.42 complete drum to drum with driveshaft $500
87 GN console $150
84 GN console $100
Kenne Bell taller then stock valve covers $80
86-87 upper intake $35
86-87 Throttlebody complete $90
86-87 Fuel rail $35
Turbo crank Std/Std $250
86-87 Turbo bracket $40
86-87 Turbo has some play but works fine $150
86-87 Power steering reservoir $50
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
85 rebuilt Long block, .030 Forged pistons, 010/.010 turbo crank,never run, still on stand $1000
D-5 convert $50
Grey/chrome strips on upper door(that pull strap attaches) $35 each in good condition.
Grand National Header panel $180
Blackout headlight bezels $60 for both
blackout marker lights $35 for drivers side and $30 for passenger side
Blackout wheel well trim $50 each piece
87 Driver power seat assembly(includes tracks,switch,switch cover and wire harness) $100
Nice 87 GN wheels $500 for all 4
Complete 86 T-type front clip(nose) $900 wont ship
Maroon console $140
Maroon buckets need recovering $120
Concert sound speaker covers(light sand grey) $60
84 Gold bucket seats $300 with rear seats $400
E mail me for any other tan(Gold) interior pieces have the entire interior.
84 Engine ,rebuilt $800 complete
84 leather and cloth seats(84 T-type) ,Sand gray, in good condition $300
Power master $190
ENGINE from 87 T-type(complete from oil pan to throttlebody/Maf to ECM) runs good $2500
87 GN long block $800
BQ tranny $400
Hydrobooster brakes $100
Electronic climate control(complete set up, will even include dash harness) $200
Passenger remote mirror(needs paint) $60
85-87 GN Front and rear seats in good condition(power driver seat also) $500
87 Grey lower concert sound door panels $100
Concert sound door speakers with mounting brackets and wire harness $75
Original GN fender extensions for car with spoiler(good black paint/has the blue on the inside) $50 for both
84-85 GN Front air dam(spoiler) $75
87 Turbo T(T-type) dash plaque $60
84 GN dash pad $100
84 GN steering column $150
Maroon steering column with tilt/cruise $150
87 Maroon console $150
Any color seat belt set(10 pieces) $100
87 locking t-tops $150 both
T-top bags $40
84 GN seats(Front leather/cloth with embroidered 6 with rear leather/cloth seat) cloth needs to be replaced but
leather is good $200
GN Console with shifter and T handle $180
steering column Non tilt $90
87 GN wheels(4) in nice condition(with center caps and lug nuts) $600
Header panel(T-type header panel with hole on top filled, GM not after market) $150
Kenne Bell valve covers with breathers $100
87 GN Electric fan $50
Radiator hold down(plate on top that hold radiator and electric fan) $40
New Cam Position sensor CAP $40
Complete 86 T-type front clip $800
GN front bumper $100
K&N cone air filter with sensor in neck $20
87 GN seat belt set $100 for all 10 seat belts
T-type header panel $150
T-type header panel with hole on top filled $150
GN spoiler (GM , 3 pieces) $175
Fuel cell $60
Shifter with T handle $50
Concert sound 2 lower door panels(gray, 87 T-type) $100
ATR Ram Air box with K&N built into it(the box is made of alum) $40
Bigger the stock front sway bar $70
NEW Richmond 3.73 gears $90
Fuel sender/fuel hanger(analog gauge) $100
Hot Air to Intercooled Conversion: Includes parts to convert from 84/85 to 86/87 Intercooled setup. $1600
ENGINE PARTS:
AC compressor(84-85 AC compressor) $40
AC lines(86-87 or 84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $30
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20
Block(109 Block) $250
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Chip(stock 86 chip) $30
Chip(stock 84 chip) $20
Coil pack(84-85) $40
Coil pack(86-87) $40
Control module(84-85) $50
Control module(86-87) $70
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(85-85 ECM) $40
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $35
Headers(factory Exhaust headers,both sides)$100
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Injector harness(86-87) $40
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $50
Intercooler fan $40
MAF(86-87 MAF) $90
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(metal, frame mounts) $35
Oil pan(Turbo oil pan) $35 each
Power steering pump(86-87) $70
Pulleys(86-87 underdrive pulleys(crank and alt)) $35
Pulley(86-87 Crank pulley with adapter) $35
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(86-87 Throttle cable) $30
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers (84-85) $30
Wire harness(84-85 engine wire harness) $150
INTERIOR:
I have every color interior parts except Green.
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound speaker covers(84 GN) $50
Console shifter plate(Plate on console that goes around the shifter)$25
Console (87 GN)$150
Dash pad no cracks(grey or Maroon) $100
Dash plaque(87 GN) $90
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $80
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
Map light $20
Radio(Stock GN radio, no EQ) $50
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $150
Shifter $35(84-87 GN, needs T handle)
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue
Visor(Nice blue passenger visor with lighted mirror) $20
Body Parts:
Blackout(Front windshield blackout trim(3) )$40
Blackout(rear window blackout trim(3) )$30
Blackout(Trunk Lid blackout trim piece) $35
Bumper(GN Front black bumper) $100
Bumper(GN Rear black bumper) $70
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Grill (86 T-type grill) $50
Grill(85 GN grill) $60
Grill Emblem(85-87 T-type grill emblem) $15
Grill emblem(87 , says "Buick") $15
Fenders(84-87 GN fenders(GM)) $80 each
Lock set(all 3 locks with key) $60
Quarter windows with blackout trim $80 for both sides
Tail lights with blackout trim $90
T-top black trim that the t-tops rest on(sort of L or boot shaped) $50
T-top boot shaped plates that the t-tops lay on $60
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror)$20
Windshield blackout trim(3) $40
Windshield chrome trim(3) $30
Wheel wells(Turbo plastic wheel wells) $80 each
Any other blackout piece e mail me I have them all
Hood(GN hood) $95-$150
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Misc:
Antenna( black manual antenna complete with mast, base and nut)$35
Antenna base nut and spacer for Power antenna with black trim $10
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
PowerMaster(complete unit) $170
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
Tranny dip stick and tube $40
Transmission oil pan(Stock 200 4r tranny pan) $25
Valve body(BQ valve body $200)
windshield wiper assembly $15
New e mail address Fortune628@wildblue.net
My cell number is 413 563 8819 reception at my new house is terrible. E mail or Pm's are best.
Received the GN spoiler today,good deal! Thanks Bob...![]()
do you still have the radiator hold down, and also the rubber bushings for the radiator ones on top. and also whats the conditon of the hold down thanks
I will still take front bumper if you still have it, I e-mailed you my shipping zip code last week but never heard back. It's 80233 Thanks let me know........
