SignUp Now!Rear is baseline suspension kit i just installed.Pinion is about 2 degrees down, strange double adjustable hocks all 4 corners.Fronts are coilovers with TRZ coilover kit and trz lower control arms and stock upper arms with global west bushings.Fab nine rearend with 3.50 gear and spool. I worked at it a year and a half to get it to work.
What are the limits on boost control? No AMS/Boostleash/etc?? or nothing at all?260 "stage II TA heads ,V1 front mount ,Precision 7675 cast wheel 76 4 bolt turbo, PTC convertor, 400 turbo, 3.50 gear, She weighs about 3300 with me on board. I'm running a local limited 8.5 class. No boost controllers or traction control allowed. I think it'll go 5.40's now that it hooks if i can get it under control.
