After going back and forth with the shop over my engine, they finally admitted that the car probably had a wiped cam. When I asked what we could do about it I was told that race engines dont have any warrenty. It didnt seem to matter that the engine was like this when I picked it up with 18 miles on it. He doesnt seem to want to take any responsibility for it. I think he ordered the wrong pushrods for it and they where to long. Here is the specs from the machine shop. See if there is anything out of wack.
Connecting Rods:
Big end Bore: 2.3745
small end bore: .9385
small end fit press: .0012
Heads:
chamber volume(cc): 47.5 cc
valve head size: Int: 1.710 Exh: 1.500
spring installed height: 1.710 1.710
spring coil bind 1.185 1.185
spring pressure closed 105# 105#
spring pressure open 265# 265#
retainer to guide / seal clearance .495
Cam:
brand TA Perf Part# TA-260-H Grind 32057 (206/206)
lobe lift: in .275 ex .275
valve lift in .440 ex .440
duration at .006 in 260@ ex 260@
duration at .050 in 206@ 206@
lobe seperation 114@
intake lobe center line:
Cam Card called for: 110@
Cam degreed in at: 108.5@
piston to valve clearance: in .170 ex .190
compression ratio: 8.46
test information: Compression 150#
------------------- Oil Pressure 60#
-------------------valve adjustment: in H ex H ??? <-- donno what that means
The shop wanted non adjustable stock length push rods to put in. When I went to order them from TA they asked me for a length. I went back to the shop and asked again about length and he told me to get stock length. I think they were to long and wiped the cam. Opinions on all this please? And what responsibility should the shop have for fixing this FUBAR?
Dave
Connecting Rods:
Heads:
Cam:
Dave
