Billet BRF 2004R with brake/rollerized/deep pan
brian
Senior Member
BRF trans, fresh & ready to go.
This is a solid bottom 10, high 9 sec capable street/strip trans.
Billet drum and input shaft, fully rollerized gear train, front pump and output shaft, custom servo, and trans brake (stage right type, but quicker, and better releasing). This is a lock up trans and has an upgraded TCC switch and new pressure switches.
The unit also has 555 and 400 boost valves, rev kit, Alto wide red band, billet anchor pin, and extra clutches throughout.
This trans also has a deep cast aluminum pan with drain plug.
$2400 outright shipped to you (cont U.S.)with core ($400) included. Look around and compare prices, this is a great deal with the core included.
1 year no B.S. warranty.
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer.
Thank you very much...
Brian hipsibri@cs.com
bump for ya Brian.. They guy with the limited will be ordering one of your trans by the middle of Feb
I so don't need this but damn if I don't want it:cool:
Just need to save a little more:(
Since there is a good deal of intetest in the other BRF with a billet drum, I thought I would bring this one TTT again.
Ray, I could change the V-B on this one as well or remove the brake.
Thank you, Brian
