- Nov 24, 2001
First off i need a certain bracket that helps hold up the engine wiring harness on the pass side, it bolts to the reciever/dryer and hangs down then bolts behind it to the fiberglass box.
See pics to find out where it goes.
In the picture, it begins where the hex headed bolt starts,goes down and screws into the fiberglass box.
I believe it is the bracket that the black plastic clip screws to, that holds up the engine wiring harness.
Grey turbo T floormats.
Billet T-stat neck.
Mini starter.
AC lines.
AC pressure switch.
Speedo grommet at firewall.
Cruise control bracket.... Screws to drivers side inner fender and the cruise vacuum pod bolts to this. Chrome would be a added plus!
Looking for misc. chrome underhood pieces, let me know what youve got.
ATR rear sway bar
New GM bushings for the Rear Suspension upper and lower control arms.
Thanks for the help
BW
Billet T-stat neck.
Mini starter.
AC lines.
AC pressure switch.
ATR rear sway bar
Thanks for the help
BW
