toofastforyou
2FAST4U
- May 25, 2001
Dave, when you say "earlier version" do you mean that they changed them and that they're no longer like yours?Yes mine are the earlier version 8800’s
Claude.
SignUp Now!Dave, when you say "earlier version" do you mean that they changed them and that they're no longer like yours?Yes mine are the earlier version 8800’s
I don't think there's any need to "upgrade" the wiring, especially since these headlights take less power than the stock halogens. Personally, I'm not crazy about the "Trucklites".The Trucklites are on Amazon with prime for $144 each. I'll probably swap to these and see how they roll with the upgraded Kirban wiring kit. The blackhawks or whatever I have really suck.
So the top and right terminals as you are facing the front of the plug?Any lights that work with the factory wiring will work with the Kirban upgrade. As mentioned, the upgrade isn’t needed, but if you’ve already got it just hook it up.
If you want to remove the Kirban upgrade later, that can be done as well.
The top and right terminals only need to be swapped with the H4 based lights.
The lights are already installed and both sets of lights come on and the brights indicator is about half way illuminated and when i turn the brights on the center light comes on the bright set and the indicator on the dash is fully illuminated.Yes, as you’re looking at the plug from the front of the car.
Just a reminder that some LED’s are made to replace our low beam headlights (H4656) and just plug right in and work.
The H4 headlights or conversions are the ones that need the terminals swapped.
Try plugging them in to see if they work before swapping the terminals.
