For those of you that have broken the little white tab off of the threaded blend air door linkage. I read in a post somewhere on here that it was discontinued Whether that's true or not good look in finding one. THere is however a workaround. At your local auto parts get a set of the HELP brand Door lock linkage ends. There is one in that set that will thread onto the rod and fit down in the little L shaped linkage.
