I guess you can say Ive got the bug of going faster, faster, faster. Last year my best E.T. and Mph was 12.20 @ 109 MPH. This year I added a turbo, I/C, and downpipe and went deep into the 11's. Awesome. Now I want to go faster yet!!
I was wondering how much power can a well prepped 109 block with a girdle, billet main caps and stock crankshaft and rods take?? Reason I ask this is because the times Ive run in my sig. is nothing more than a stock bottom end with arp main studs, forged pistons, and a flat tappet cam. No billet caps or anything. Good rod bolts of course. But at the power level Im making right now Im getting concerned about the bottom end. I really don't want to be a member of the DOTC quite yet. I haven't had any serious detonation yet but If I do Im afraid of the outcome at 24psi boost.
I do plan this winter to build another engine and save my stocker. I would like to strengthen the bottom end( girdle, steel billet main caps) add a roller cam and ported heads and intake and of course a bigger turrrbo!:biggrin: Should I buy a forged steel crank for piece of mind along with some better rods, or just use the factory pieces?? Ive heard people say if the block, crank, and rods are properly prepped they can take some serious abuse.
I would like to get the car into the mid-high 10's. Reliably.
Currently I have a TE60 turbo with the garrett .63 exhaust housing. What turbo would you guys and gals recommend also??
Thanks.
Thanks.
