Hello all,
Here is my problem I need a new block! I removed my engine at last for a spun rod bearing( I was right) only to find two of my wrist pins had badly scored the cyl. They look like they have been that way for a while. I dont even need to mic. it to tell it's shot. Crank looks OK a 10/10 should take care of it. 2 rod & pistons??? I 'll replace all just to be sure. What are the best parts to use. Street car stored alot,79k I was getting ready to take care of some blowhard and his TA at work! I will be needing all your help in the future-I have till spring and it is cold in MI anyway. This will be slow to do,working with what I have left after setting the EX!! up for awhile.
Getting to my question- what blocks can i use with my current engine parts. such as--
85 block
4.1 from what cars?
87 block/with mods
N/A block?
After getting some input I'll go junk yard searching around here first. I want to keep this car a hot air. I've owned this car since new in 84. This is my set-up-
te49-new, 4mi-spun rod bearing on first outing!
36# injectors-new
ATR SS headers & crossover-new
accufab
340 Walbro
hotwire
valve springs,rocker shafts
boost & knock gages
Magnecores
Tlink
I will listen to everyone, I want it to be done right,even if it takes longer.
Thanks Marty U
85 block
4.1 from what cars?
87 block/with mods
N/A block?
36# injectors-new
accufab
340 Walbro
hotwire
boost & knock gages
Magnecores
Tlink
Thanks Marty U
