USMC_Turbo6
- Dec 13, 2009
When to use one and when not to use one?
SignUp Now!When to use one.when you own a Honda. When not to use one. When you own a Buick. Sorry I couldn't resist.When to use one and when not to use one?
So you have 2 then?When to use?
-When you put a manual transmission in.
-When you don't like the unique sound of a Buick V6.
-When you feel like wasting money.
-When you don't have a MAF sensor anymore.
-When you want to impress the ghetto guys with your big fart sound.
-When you want to protect a turbo that chances are you will upgrade before you brake it.
-When you road race.
-When you want something purple and green under you hood.
-When you sell the Buick and buy something Japanese.
-When you listen to all those people that say you need one.
-When you get one cheap from a Buick vendor who couldn't sell it to anyone else.
When not to use?
-When your completely happy with the fact that you don't need one.
So you have 2 then?![]()
Well I always was thinking the same thing until Bison ( Brian ) said they Do have value if set up right.
I like a the debate about about certain parts for our car
If I was road racing and had to rapidly open and close the throttle Id run one for sure. The valve has to be setup to work properly for the type of driving and desired effect. I've seen them leak boost under power and cause a bunch of other problems. If you are getting surge at wot then the engine can't swallow the air and the turbo isn't running anywhere near where it should be. Anything that has fast response or requires lower drive pressures to obtain a high pressure ratio will typically surge at part throttle. The compressor is trying to move x amount of air but it isn't making it into the engine. Switching compressor or turbine can usually eliminate the part throttle surging.
Kind of like I said in post 11 and post 7.
