LemansWagon
- Jan 17, 2008
Anybody here run a blow through system with a q-jet?
Is he running a q-jet? I am curious as to what mods he made to make it work. I've always been a q-jet fan and have years of experience tuning them but it's all N/A. I've always preferred them to holleys and have a shelf full of over a dozen of them. I was going to use a Holley in my blow thru until I saw a 455 Pontiac in a magazine pushing a ridiculous amout of hp through a single qjet.
I've seen/read this article myself and a lot of the info is bogus and I wrote to them and called them out on it They were like "oh you have done your R&d then"
FACTS: The accelerator pump will leak with boost over 10psi(it leaks under that too just not as much, still dangerous)
They don't like a whole lot of fuel pressure but this is mandatory for blowthru:
7psi base fuel pressure+10psi boost=17psi fuel pressure inside the carb with a 1:1 boost referenced fuel pressure regulator.
They are very finiky with keeping a constant AFR while in boost.
It's hard to seal the carb up tight for boost, it can be done but it's that much more work that other sqaure bore carbs don't require.
The internal mods are not hard to perform to get it to flow the fuel needed, It's more challenging to get the throttle shafts sealed up and get the secondary side set up to not go lean in boost.
I have built a good blowthru Q-jet and it worked quite well(to a point) and I'd be more than happy to show you pics, tell you the places to drill and smooth and point you in the right direction if your serial about building a blowthru Q-jet, but I just know you will upgrade after you say many choice curse words about the Q-jet while tuning.
After going this route and been there, I'll keep the square bore carb over my Q-jet for blowthru.
LemansWagon said:I figured a carb would be cheaper and easier than getting the harness and some 90 lb injectors. Not looking that way anymore....
