Well I joined the club. Engine has 110k miles and never has been opened. Ran a compression test and here is what I got,
1-125psi
2-125psi
3-140psi
4-0psi...oh my!
5-130psi
6-125psi
There is NO water in the oil or oil in the coolant, oil and plugs all are clean. I would assume I blew #4 into the lifter valley as I get oil out both breathers if the engine is running. You can hear 4's compression being leaked while running. I ran these compression nubers with the engine cold. My idle oil pressure is 25psi, cruise 50+, WOT 70+.
Here is what I'm planning. Pull the engine and install a new roller set-up and champion irons. Do you all think my rotating assembly is in good enough shape to leave it be? It does have 110k on it, but never ran over stock boost levels for 90k of it. Thanks for the input!
1-125psi
2-125psi
3-140psi
4-0psi...oh my!
5-130psi
6-125psi
