this kit uses a standalone 3 bar map sesnsor with a seperate boost reference then the stock map sensor (just in case it was important)
my question is that i have the chip made up before i put the alky kit on the car, so now when the car goes into WOT it sort bogs out i have the setting on the little black control box set on 6 this kit had a standalone map sensor which references boost i think its a 3 bar. well the car bogs when its injeting then when i turn it off NO ALKY the car runs hard with no bogging and goes into the boost hard.
does this mean i have to redo the chip as ERic of TT told me that i would be able to get away with running the chip could it be the setting on the control box is to high? i do know that it does come on as soon as it reads boost on the gauge according to the little green led.
do i have to open up the back of the PAC and tune it down in there for what its worth the alky comes on at about 0-3psi like right when it goes into boost then i start feeling the layover,hold back,bogging, stumbling feeling when i turn it off she runs fine.
any help would be great.
