Bolt in 9" rear
Otto J
Moser 9" drop in G body rear.Welded back brace.
Not sure of axle splines,But is has a Moser Aluminum Center section,Spool,3.90 gears
Moser Aluminum big bearing support large drum brakes.
Also A Wolfe double adjustable anti roll bar and Wolfe upper and lowers.
2700 you pay shipping
This is a pretty industructible rear,The aluminum center section alone is over 1200 and lighter and stronger than the cast version.
1200 Center section
825 housing and axles
150 brakes
915 wolfe setup
Over 3000 in parts
price is negotiable
pics
re:Balls deep in CT as well
How low will you go? $2000.00 pick up? .......Dave in Wallyworld CT
John made an offer on the rear,If someone is willing to buy the suspension(uppers and lowers and dual wolfe bar)
Ill seperate.
The wolfe bar was welded in,I removed it without hurting any parts of it.
Suspension new is 950 on Wolfes site.
ill sell it for 600.
And let the rear go for 1700 without it.
I pulled and axle today.
The axles are 35 spline gun drilled axles
rear,,,
Otto, i see you are awake. i looked at one at a swap meet in indy today it had a 4.1/2 bolt pattern regular ford, it was out of a 69 chevelle, and it was priced more than yours, good luck, oc,
I know what its worth,I got it in a deal with some other parts and figured i would pass it on and save someone money.
2100 is the lowest im going,Ill bolt it in my street car if i have to go less
I pmed you back on Yellow bullet,Didnt get a chance to call you,but did not see a response.
Someone local called with the buy it now price from ebay though.
Sorry
