Boooost
Thanks for the vid Wes.. I assume this was with the Stage motor?? If not:eek:
That was the first run off the trailer low boost and timing 2 step set for the peanut . That was the stage 2 but dont worry the little 109 will run the same with that turbo . I barely had any time to finish the car had 2 engines to build and 2 track rentals in one week so all in all im happy with the out come .
Laz,
I know it's only a matter of time before you guys get the 109 to run the same #'s as the Stage2 and now that Precision has released the GT42-70 in a 3-bolt maybe it will even be TSM legal when it does it!:eek: :cool:
In any event, Roy's car was hauling a$$ as usual and it's good to hear all the other Buicks ran strong as well!:smile:
Laz...
You guys rule!!!
Keep up the good work bro.
Patrick
Quiky One we ran 9.32@ reynolds and it nosed over at 1000 feet or so no power above 5400 in high gear i kinda figured it was a fuel problem cause it affected the whole motor and it burned the plug on cylinder #1 .Video - Boost at Reynolds, GA Southeast Muscle Car Challenge. Nov 3rd & 4th.. I would have expected it to run 9.20s in tsm trim just did not have enough time, sleep or data to find the problem till it was too late .
Patrick good to see you back on here bud :D . I know your workin in a buick project again so looking foward to seeing you online more .Laz
Patrick, another Buick? come on man gimme a call
