Jan 16, 2013 #21 L Liv4dnzz New Member Joined Jan 7, 2013 Messages 29 perfect, but why do you still have the solenoid on? "Your bleeding off air just before the solenoid with manual boost bleed valve"
Jan 16, 2013 #22 H HelloBozos A Bozo in Buick Joined Feb 9, 2011 Messages 1,047 Liv4dnzz said: perfect, but why do you still have the solenoid on? "Your bleeding off air just before the solenoid with manual boost bleed valve" Click to expand... some chips need it,i ran mine unhooked, (if the turbo's old, you can get oil mist out from it,solenoid has sponge filter,,Wire Tie Tight All Rubber vacuum lines to there sources or you will see 30psi boost...Not Good)
Jan 16, 2013 #23 TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Messages 6,675 Pictures say 1000 words. Perhaps these will assist you...... Call Eric @ TurboTweek about your chip. Attachments 104_0858.JPG 3.2 MB · Views: 155 104_0860.JPG 1.9 MB · Views: 137 104_0859.JPG 1.4 MB · Views: 173 104_0861.JPG 1.4 MB · Views: 162 104_0857.JPG 2.3 MB · Views: 156
