SignUp Now!For what it's worth I installed an RJC boost controller on my 23 psi car and saw hardly any difference in spool up. But others swear by them.
Make sure your WG rod is set tight enough to realize the benefit. If its set too loose, the WG may still start sneaking open before you want it too even with the RJC on there.
My my old TA61 spooled pretty well with the RJC controller on it.
With my new 6265 DBB, I left the RJC off of it for now becasue I did not want it spooling so fast that it blew the tires off.
im runnin 13-15 pounds of boost on 91 octane and thinking of using an rjc boost controller for the quicker spool up.. For this tame amount of boost will there be any noticible change in the spool up??
