- Apr 5, 2009
I have been working on this project for awhile now. You can see my mods in my signature of my 86. I have a TIAL MVI2.5 adjustable spring wastegate actuator. Actuator rod is short as possible which gives 1/16 preload onto by puck arm in the downpipe. When I follow the spring rating Tial recommends I have way too much boost through the sweep of 0-100% TPS. for instance, the blue spring is 23 PSI at 40% throttle input. The softest spring pressure will not hold the gate and it basically bypasses. With a Green Spring I have solid throttle response and I can get 60% TPS input at 25PSI. What options or experience with internal gates does anyone have for me. Thanks in advance.
I have a Mac Valve controller from Bob Bailey, but he wants my mechanical portion refined before we use the boost duty table to 1-2 actual Boost.
