Right now, I'm using a "bleeder" valve mounted on the passenger side valve cover which works fine, but I also have an in-car boost controller that is not connected right now and I would like to know how to hook it up so I can adjust the boost while making runs down the track?... Any help would be appreciated! Thanks, 'bye, Claude.
I can't compare this to any other kind, but mine is Ramchargers and I like it. Set the wastegate at 22lbs and then leave it alone. Min. of 15 to a max. of 22. Now I have to set it to drop back to lower boost in 3rd and 4th gears. Now the question is where did I put the directions.
