If you are using head bolts,I would use studs next time. IMO nothing wrong with going back with stock gaskets again.
got studs on there. do you think this would cause the problem i am having. is boost blowing by the ring
as far as metal i only found 5 little specs and the other thing i checked the cam sensor with tool and the light was out i turned it counterclockwise 1/8 inch and the light came on so it was an 1/8 inch out dont know how many degrees that is. also the ring on the sensor was heavily corroded.Head gaskets don't look too bad. Why do say they are blown? I can't see them causing any issue. Maybe blowing by a little but the rings are still intact. Surely not the cause of metal particles.
Find the source of the metal debris.
The "graphite" on the filter is metal. That did not come from the head gasket. Something had to get ground up.
Keep digging, you'll find it.
Don't know why it's blue, looks grey to me. Prolly aluminum.
I Got A Chip From Eric My Car Ran Horrible Black Smoke Came Out The Back Sputter It Ran Real Rich Put The Stock Chip Back In Car Ran Great
While the gaskets look like theyre getting pushed, it isnt your issue. The cam sensor being mis-aligned.. that could cuase issues.
Pull your lifters out one at a time and look at their bottoms for issues.. they all should be nice and flat on a flat tappet cam. This is one sure way to tell if the cam is toast, as you can not have a perfect lifter and a wiped out lobe.
If it is the cam sensor, its a pisser. While I have never had to chase down a mis-aligned cam sensor, there are plenty of threads of those who have.
Make sure you get 85 FT lbs on the upper middle head bolts to help clamp er down.
Cant think of anything else. :redface:
thanks85 is fine on the rest. Put lube on both sides of the washer.
