Sounds like you're suffering from compressor surge (classic symptoms). Now, the 64 thousand dollar question is how to cure it. Hmmm good question, and I don't have a good answer except that sometimes it can be cured by changing the volume if the plumbing between the compressor output and the doghouse.
Hopefully others will have some input on compressor surge cures.
It's the alky. It makes the charge too dense for the motor to take it all at part throttle. When I turn my alky off and set max boost at 17psi or whatever, there are no surge issues at any throttle position or boost. When the alky is on, I just keep it below 12psi or above 15psi with my foot and no surge issues then either. I've tried tuning the alky controller every which way and getting the surge window down to this 3psi range is the best I could do while still having it do what I need above 15psi.
And as Bob mentioned, TE44s are surge happy anyway.
