If you bought a replacement switch for the stock one there are no adjustment.
If you bought an aftermarket plain ol' hobbes switch, then the set screw in the top is for adjusting boost level that the switch activates at. The two screws on the side are for electrical connections. The two screw posts are connected when the desired boost level is reached.
No RPM at all.
