Having a hard time deciding what to do about fueling... Keep in mind, I am keeping the 60's in there, running a cooler plug, monitoring with a hood mounted fuel pressure gauge, scanmaster, and Innovative WBO2. I have an old 340 in tank in now.
My decision is what else to do with regards to:
1. Run a volt booster and call it a day. $90 shipped (gbody parts) (Any issues running this with alky? I remember hearing Razor suggesting not to run it due to elect interference)
2. Swap out the intank fuel pump for a DW. $169 + shipping (ArizonaGN)
3. Leave the old pump in there, and like suggested above add an inline, which would have to be switched with an hobbes switch/harness. ~$100 for a pump, plus another ~$40+ for a harness and switch? Seems like the off-line pump would be a restriction when not engaged
Seems the most straightforward approach would be to swap out the intank. Would that be sufficient to push the 60’s to their end? If the 340 is pushing the 1:1 I need, is it even needed?
Any guidance would be appreciated.
Also, I have a spare fuel rail, with an AN fitting on the pass side. If I run the 60’s, and any of the above situations above (booster, inline, or intank) is there anything I should do/could do with the rail, return, feed?
If I were keeping the car, I would go balls to the wall with dual pumps or a huge single external, new lines, etc, etc. But, I am trying to do this on somewhat of a budget before I sell it...
