I know these have been on the market for awhile how do they compare to the garret's GT's?
They like high PR's and flow insane amounts of air for their inducer size. Only problem with them has been the selection of housings and availability, but we are working on that. Also we are CNC'ing alot of custom pieces that will allow us to fit a broader group of the performance market. Some of our buick customers have been very happy with the units...I'm sure some of them are members here.
JZ
Jose,
Do you offer the units in smaller sizes than the 70MM?
If so what size wheels for the 300 series frame?
John we can build them pretty much anyway you want. I can do smaller then 70mm in any of the chassis now. Are you just wanting something that will flow stupid amounts of air in a T4 chassis compared to say a 66mm Garrett unit? A garrett 66mm or 67mm will flow in the 68-73 lbs/min of course the pressure ratio varies, or at least that is what we have seen on the flow bench. An ETT 66 will flow in the 79-80 lbs region.
Is there a GT4294 close to/equivalent in a BW turbo?
I've been thinking about a T4 GT4294 70mm version with 1.01 housing on stock sized buick v6 stock block.
Just to make more power than a 3 bolt 70GTQ at lower boost and less backpressure.
Extended tips mean lighter, bigger wheels, right?
Jose,
What I will eventually be looking for are twins with a t4 flange
that would give me room to make 1600hp but would run ok at lower levels.
I already have 3 inch down pipes but I can weld an adapter to step them down from 3.5 turbo outlets if need be.
Let me know what you would recommend for a 274 V6 that can spin to 8K.
