SignUp Now!Anthony K said:i have -6 Aeroquip, and all "rubber" will break down unless water is being pumped. cut open a #8 fuel line after a few years and see what it looks like, not to mention the fuel filter
Blown&Injected said:Accidentally drove over a 45* hose end and broke it so it is sitting on my shelf right now - it has been used in my fuel system for many many many years. Often with pure race fuel in the lines for months on end - looks perfect.
From Summit Racing's Web Site:
BTW all the hose says about the same thing.
Brand: Earl's Performance Plumbing
Product Line: Earl's Performance Auto-Flex Hose
Hose Size: -6 AN
Length (ft): 20
Teflon Lined: No
Outer Material: Braided stainless steel
Fits Hose End Style
Auto-Fit,
Auto-Mate
Fluid Type
Engine oil,
Gasoline,
Transmission oil
Anthony K said:you have magic hose then, pull the hose end off and tell me if it looks perfect, there will be peices of black hose in there from the fuel breaking it down. unless you use Earls one time ends, check an Aeroquip. it probably "looked" good.....wet....... did you dry it off/out? and then look at it? why after time does rubber hose get soft? musshy? chemicals acting on the rubber,breaking it down.
85HOT-T said:were is a good place to get these lines? What length should I get, 3' 6'?
