Pulled my 87 GN out of moth balls Friday. Drove for 1 hour to a car show and 1 hour back. My brakes seemed soft. Got home ok. The next day there was a small puddle of brake fluid on the concrete. So I went looking for the point of the leak but could not find it. The fluid on the brake reservoir was only on the bottom of the reservoir, brakes mount, steering coupler boot, top of upper swing arm, the proportioning valve and the frame. Today I plan on removing the chrome plate from around the bowl and look again. Writing and talking things out loud sometimes helps me see things clearer. May be it was leaking around the rubber on the top of the bowl or reservoir. If it did leak there the next question is why is it leaking there? TIA
