Brake light problems?
badass86
I've got a 86GN with 40,000 miles on it just put on a rebuilt power master cylinder from kirban performance had the brake system flushed and also bleeded the brakes.brake pedal is still kind of low and brake on dash still comes on help please! :confused: :confused:
Sounds like you still have air in the system.
You might just one at time starting with the farthest one away from the master cylinder, crack it lose and let it gravity bleed. The order would be R/R, then L/R, then R/F, then L/F. It takes a while, so don't get in a hurry.
It should be a pretty steady drip. As you get done with one, tighten it before going to the next one.
Then have a friend do the pedal bleeding routine with you.
