May 2, 2011 #1 C chops Member Joined Dec 18, 2010 Messages 636 Does the brake pedal have to be change from power master to vacuum?
May 2, 2011 #2 C chops Member Joined Dec 18, 2010 Messages 636 vacuum brakes Am going to call the parts store for vac brakes I was told to get a set up for an 87 monte carlo v6 is that correct
May 2, 2011 #3 C cruzn57 Still plays with cars! Joined Apr 18, 2002 Messages 4,867 yes, pedal needs changing find one at junk yard, it will line up the push rod/ hookup. hint, remove drivers seat, makes under dash work alot easier.
May 2, 2011 #4 R Red Regal T Senior Member Joined May 24, 2001 Messages 19,243 chops1972 said: Am going to call the parts store for vac brakes I was told to get a set up for an 87 monte carlo v6 is that correct Click to expand... All G-body vacuum setups are the same. Attachments 7044_lg.jpg 76 KB · Views: 140
May 2, 2011 #5 T turbojd Well-Known Member Joined Dec 27, 2005 Messages 1,983 chops1972 said: Does the brake pedal have to be change from power master to vacuum? Click to expand... It does have to be changed, if you don't feel like doing any drilling. I used my powermaster brake pedal, I just marked it where it had to be drilled and all is good.
May 2, 2011 #6 turbojay Active Member Joined Feb 14, 2009 Messages 953 I've got an extra one. PM me if you want it.
