SignUp Now!I have an 86 GN and the brakes are acting up. If I hit the pedal for an emergency stop there is a good 3 second delay before the brakes grab. What would be causing this delay?
Other than that the brakes work well, no leaks, and fluid level is fine.
If it's a Power Master system it's most likely the accumulator ball.
There is a ton of info on the PM brake system on this site. The search feature is your friend.![]()
I'd be interested to know how you recharged your accumulator? I replaced a weak accumulator ball (ironically it was TurboTGuy who sold me a spare) and the replacement fixed the problem I was having (brake light blipping on from time to time with a hard brake, but everything else in the diagnostic tree checking out). I'd like to recharge my original accumulator because everything else in the system works fine (knock on wood).Thanks for the help. After not dealing with PowerMonster issues for almost a decade I guess I had a brain fart because I should have known this. I recharged my Accumulator back to 300psi and now it's back to braking like it should.
So, you're saying you can "refurbish" an accumulator ball to spec here in the present day?
I'd be willing to pay for such a service, so long as it is priced fairly.
My car is far from stock so if it looks a bit "different", I have no issues.
What is important to me is if it STOPS when I push the pedal.
It's true that many dealerships just want customers to keep buying parts that fail, it's a guaranteed money-maker. I'm surprised your rechargeable accumulator and pressure switch solutions didn't get much response here. But I'll be honest and say I've noticed there's a bit of an "old man's club" here and not much respect gets shown to newer members, even those who have plenty of mechanical background. Maybe that played a part?
Like TurboTGuy said, I too would be quite interested to know more about your PM brake solutions. If by private message, that's fine by me.![]()
