Mushy pedal is usually caused by air in the system, but can also be worn brake flexible lines.
Since you likely still have the original lines on it, have them replaced (both front corners and the one over the rear axle) and the system flushed and bled. If the brake light still comes on after that, you have a leaking PowerMaster and it should be replaced.
