Brand New Stroker 109 Shortblocks
A billet roller installed-something around 212 or 218.in a new stroker block with billet caps.
Hi Bryan, What would the up change be for a short block with TTA Pistons?
Thanks!
That would cost $6,521.41 and we would need you to send us the timing cover, oil slinger,and fasteners you would like to use so we can set the cam thrust.
It would be the short block you mentioned, a billet cam with grind of your choice, "A" kit for the front of the cam, billet timing set, timing cover gasket, degree the cam, set cam thrust, and install timing cover.
Have a great Thanksgiving!!!!
Thanks!
James,
All we would have to do is change the dish volume for you and the cost would be $125. We can then make the compression ratio whatever you want it to be within reason of coarse.
