TURBOPOWERED68
David
- Jan 31, 2006
AWESOME work
i wish i wish
i wish i wish
LOL That's what a lot of people don't realize. It really doesn't take that much to do fabrication but it does take an understanding of it and a bit of imagination.![]()
You just need to develope the skills is all. Practice with simple stuff first and then go from there.some people have the skills me and a bunch others don't LOL
pretty muchYou just need to develope the skills is all. Practice with simple stuff first and then go from there.![]()
doing a downpipe for our cars is fun. doing headers like in this thread is more of a pain in the butt. if you do make an attempt at headers, might i suggest making a mild steel set first cause its cheaper to mess up. then if you really want to take the dive (cost wise) into stainless headers then you have more info to make a better decision.Once I have enough practice welding, I am going to try and make up some headers.. They look like more fun than anything else to fabricate..
Can't argue with this at all. I'm remaking a set of stainless after market headers but don't need a lot of parts to do it. Drivers side needs different flanges on it for the cross over pipe and the passenger side needs the most. Total reconfiguring of the pipes for the HA set up. Then I've got to do the down pipe and waste gate attachment as well as the up pipe. Not really looking foward to that myself but no one makes the parts I want so.....doing a downpipe for our cars is fun. doing headers like in this thread is more of a pain in the butt. if you do make an attempt at headers, might i suggest making a mild steel set first cause its cheaper to mess up. then if you really want to take the dive (cost wise) into stainless headers then you have more info to make a better decision.
I still have been considering making my own headers. May I ask where you got your tubing from, and how much of it did you order? Just want to get a ballpark of the materials ill need (probably 2x what you did from mistakes!)
Zack
What is the problem using mild 16g for the headers? I was thinking about doing a forward facing setup like I've seen on some s2's.
very nice work slim
At those material prices buying a set of TA headers(stock replacement) sounds like a smokin deal unless you are just in it for the challenge, that or building race headers....The cost difference between material for Mild steel and stainless isn't as much as you would think. For a set of v6 headers I use 6 x 180* header tube size u bends, a pair of cone engineering collectors and 4 x 2.5" u bends for the crossover. I use mild steel flanges and v-bands even with stainless tube because it warps less. So the cost of the tube and collectors is the only real difference.
Material for a set of 304 stainless headers is about $750
Material for a set of mild steel headers is about $600
After you spend 40 hours cutting, fitting and welding the headers, that $150 won't be a big deal. Coating would be at least twice that. Stainless takes a little more work to weld because you need to backpurge the tubes as you weld them, but you can rent an extra cylinder from your welding shop and they refund the money when you return the bottle. The only time you'll have a big cost difference is when you use 321 stainless. It is easily tripple the material cost.
