1987 Buick Regal T-Type
3.8L Turbo
New engine and transmission
Symptoms
After the rebuild, drove the car for 3-4 hrs then started to run like crap. Hesitant then a pre-detonation knocking coming from the exhaust headers when warm.
History
I bought this car from a friend after sitting for 8 yrs. He pulled it apart cause the trans blew. The engine ran fine. It was in bags and boxes when I got it. He had all the machine work done to the block (Honed and washed) and rebuilt heads.
Rebuild
I rebuilt the entire engine stock and new trans. New water pump, alternator, cam, lifters, head work, rings, wrist pins, crank polished, gaskets, all bearings, cam tensioner, timing set, oil pump, seals, cleaned everything out, etc.
What to do?
Keep in mind this car was running and rolling for 3-4 hrs before this problem occurred. Still running retard (BTDC on edge of scale). I am thinking ignition module? Coil packs?
We are developing a love hate relationship. Any feedback would be greatly appreciated. If you are in the Maryland area, the beer of your choice is waiting for you if you can take a look!
3.8L Turbo
Symptoms
Figuring it was ignition cause it was running BTDC (Was like an inch off the scale), I replaced the crank position sensor and knock sensor. Reset the cam position sensor as well. Its not so retard now but still on the edge of the scale. Still knocking lightly when warm. Runs and drives. No engine light.History
Rebuild
What to do?
