build a (electric) trans brake?
413turbo
I got CK's book. looking over it, i see some great stuff. I understand that a transbrake locks manual first and reverse at the same time. to have a brake with a creep feature, it would have to be electric, correct? and then can i just put a liquid solinoid in that routes fluid to both the first and reverse channels?
i'm sure it isn't, but WHY couldn't this be as easy as installing a lineloc?
Firstly, all the channels need to be emptied from pressure also, that's why the R is exhausted while on 1st and filling it with a hydraulic solenoid does no good other than exhaust pump pressure.
If you have a trans that has a TB available, buy it.
