Building a 7sec 87GN Drag-n-Drive car with V6 Stage 1 heads!
Well Sick Week didn't go as planned.
We got there Saturday to test and had a wonderful day. The track was on point, the weather was perfect, the car was running well and we ended the day with a 1.22 sixty and 5.22@136 on a relatively mild tune.
We got back Sunday morning and the track was definitely more crowded. We made one hit early that went well but the car slowed down a little with the shock adjustment we tried and as the day progressed it just got worse. That first pass ended up being the ONLY pass we made that day that the car didn't blow the tires off. Saturday we made 4-5 passes and never spun. WTF
On the one pass we did make on Sunday we found the crankcase pressures got really high and suspected the vacuum pump was backing up. So we disconnected it and just vented the crankcase which fixed the issue. I had been messing with that vacuum pump for awhile and thought I could get it to work but it just can not keep up. Possibly a larger vacuum pump will work which I may try but with no pump I had zero crankcase pressure which was good to see. It reached 9psi with the vacuum pump and was pulling close to a quart of oil out.
We did get the car tech in on Sunday which was nice to be able to get that done early as it usually takes most of the day to get done on Tech Day.
Tech Day was a total washout, it never stopped raining the entire day. I was at the end of the life cycle for my tires and had a new set put on my Mickey Thompson at the track which worked out well. We put all the suspension settings back to what we ran on Saturday and neutered the starting line tune up and waited for Day 1.
Race Day #1. The morning was cold and wet and the track was still soaked. They didn't get the day started until almost 11:30 and decided to put the slower C&D groups down the track first with the AB Radial group going next to last. We are usually the first. We didn't get called to the lanes until almost 3pm.
When I rolled up to the line Ray said the track was a mess and had strings of glue coming off my brand new tires. I did a good burnout to clean up the new tires, staged and the car spun as soon as I let go of the button. I pedaled it some and stayed in it for a 10.32 pass and was bummed it was not going to be a one and done day and we now had to wait for the all run session. This really sucked because the drive to Bradenton was the longest one at 320+ miles and it was already close to 4pm when we completed that pass. Day light was fading and they still had a shit ton of cars in the lanes. So we waited.
I backed the starting line tune up down to softer than when we started testing but it didn't matter, They ended up calling the day around 5:30 and were finishing out the lanes so everyone got one run for the day and I had to turn in a 10.32 slip while the top guy in the class Cooper Bogetti managed a clean 8.52. That is going to screw us for the week bad but were weren't the only ones and I still mathematically had a shot since Cooper was not legal to run under 8.50. I needed to turn up my game though and unfortunately we didnt not get enough testing with the new combo to know exactly what the car was capable of. We loaded up and got on the road around 6:30 in the dark. The drive to Bradenton was pretty unremarkable. On tech day I did get the Gearvendor hooked up and working and we tested it with the Holley controlling it and it worked fantastic. Being able to blast down I75 at 75mph and 2600rpm really saved us a shit ton of time and an exhaustingly long trip. With the one check point it still took over 7 hours and we didn't get into the hotel room until alomst 2am.
The one checkpoint was pretty cool a new race track, we didn't hang out long though
We were back up at 5:30 am and at the track by 7am with a refreshing 3 hours of sleep. We got the car swapped over, on the way down we ended up running pump gas in the car and noticed the car ran really rich with the ethanol content down around 20%. We ended up putting E85 back in which brought it back up over 50% cleaned it up a lot and the car really ran a lot better. We drained the gas and were running a leaded race blend E85 from Renegade on the track.
Bradenton had a good track prep, I know SGMP is also known for being a good track with the the weather struggles they had it was difficult. Not so much in Bradenton it was actually pretty warm that day. They called AB radial as the second class that day. I staged bumped in and had to hit the bump a second time and the car just launched. I think since the track was so sticky it jerked the car some and my thumb must of come off the t-brake enough to release it. The log showed it engaged twice but IDK, it sucked as I did not set the tree or get a time slip, so once again we had to wait for all run. The car did hook and I made a full pass but the car was really lazy and seemed to really slow down. Ended up we forgot to remove the air filter on the new inlet Ray built!!
To this point we are like WTF, Drag week was almost to easy and Sick Week has been a shit show up to this point. We have a car that should be in quarantine and on top of the class and we can't even get down the track. It is now Tuesday and we haven't made a clean pass on the car since Saturday!
Finally we got a hit on the car with a very mild tune up. The car felt good but was still off a little bit from where it should have been but it was a nice A to B easy peasy 8.32 pass. We handed in the slip and got on the road. The math was easy a 10.32 and a 8.32 now gave us a 9.32 avg and moved us from 18/23 to 4th. Not bad, to date I also believe it was the fastest pass in the Street Freaks class. If we leave the car like this we have a real shot, but we also know the car has a shit ton more left it in for later in the week.
Loaded up and on our way. We put the 50% ethanol gas we had in the tank back in and got on the road. We needed to fill up when we left and only had a few options for an E85 station which were all out of the way. We stopped and decided to just run pump gas again. The car ran fine but it did not want to idle well and surged a bunch. The Billet Atomizer injectors really like the ethanol a whole lot better and seemed to struggle with the low pulse width needed for pump gas.
We made the first check point fueled up and started our trek across the state to the other side through the forest preserve and swamps of central Florida. There was nothing along this road and at night it was pitch black with no lights other than headlights of cars and trucks blasting down the two lane road. Fortunately the majority of traffic was Sick Week'ers at some time around 8pm or so the car decided to just die on the side of the road. We pulled over into the gas/weeds to get off the road and saw smoke and smelt gas really bad. We looked it over and were not able to find anything visibly wrong. We tried cranking the motor and it abruptly stopped cranking which wasn't good. Ray was literally getting eaten alive by what ever creatures lived in that grass, it was pitch black and we had semis and traffic blasting by use at 70 mph. Not a good scene and very dangerous.
Fortunately we had a bunch of racers stop to help. We decided we need to get the car off the road to a safer location adn there was a driveway or road right up a little ways. I did not have the tow hook on the car and I did pack it but for some reason we could not find it. After some quality engineering we cut the safety chain off the trailer and was able to fit it in the hole for the tow hook put a bolt through it and make a make shift tow strap which we tied to the the rear bumper support of a 1957 Chevy station wagon gasser! These guys saved our asses and ended up towing up at least 5 miles to the Racetracs gas station.
The name on thier car was Lucky Draw as they won the car in an online raffle by Mike Finnegan. We actually ran into these guys earlier at a taco stand the story about winning the car last month blowing up the motor and then doing Sick Week with it was incredible. These guys were definitely having a blast doing this.
Us not so much lol! We still weren't out of the race since you are allowed to be towed to safety. This Racetrac was at the end of this 40-50 mile stretch adn literally everyone stopped at it. When we got towed in the place was packed with racers. We got to work on the car and found that injectors had locked up and hydrolocked the motor. We ended up getting it to pump the gas out but when we went to try and start it again it did the same thing. After messing with it and getting a lot of expert help from Brandon Doller we finally called it a day around midnight. We thought the motor lost a timing chain at first and called our buddy to come get us with his truck and trailer. We were close to I95 on the east coast down near Melbourne close to 400 miles away from the truck and trailer. Literally the furthest distanxe you can possibly be on the route. We worked on the car until Murray showed up at a little after midnight. We towed 2.5 hours to his place and got a few hours sleep got up and continued on to Georgia. We loaded up and then headed home getting in at 8am Friday running on a total of 7hours of sleep since Tuesday.
I am still taking it all in, even as prepared as we were we still didnt do well and we brought a car that should have dominated our class. But we were again untested, we never ran pump gas in the car before and we had a new cam combo that added a lot of power down low and made the front half of the track a little more difficult. Both of these things stung on on this event.
The good news is after getting the car home, I took the injectors apart and cleaned them drained the pump gas and put the race tune and race E85 back in the car and it fired right up like nothing ever happened. It is what it is had we known the exact problem then we would have been able to continue but we didn't. Plus we were running into goofy battery and starter issues at the same time that ended up being simple problems too. As for now, I am going to focus on getting this car finally sorted out. Sick Week is really difficult when you are coming from Ohio in January. Winter makes everthing 100x more difficult and we experienced that 2 years in a row now. Plus the days are really short even in Florida which means almost all your driving is done at night and the tracks shut down early. I am not sure I will go back next year but we will see. I am signed up for Sick at the Rock in April where I hope to get some good track time on the car and finally get it in the 7s.
Sounds like you had a big week. Those drag and drive's are pretty brutal. Thanks for the details!
What a weird failure! Wondered what happened to you guys. Never got a chance to come say hi.
Thanks, it is way more brutal when you don't have your shit fully sorted out that's for sure. That's twice now we got stuck and both times in not so ideal situations. The injectors locking up on the drive was a surprise for us especially considering how well it did at Drag Week which we only ran on ethanol. If we actually tested driving it on pump gas we would have known, maybe not that they would lock up but at least that the car did not run as well and the injectors didn't like running on pump gas.
Here is the video of the 8.32 pass at Bradenton. Tune-up was pretty mild and the starting line tune up was completely neutered.
We are going to Sick at the Rock in April and with three days of a good track we hope to get the car sorted out and running well.
Thats pretty awesome and in my neck of the woods.
What if you did win your class, what would the actual prize $$$ be?
I admire your dedication, my definition of "fun" is waay different but I like watching it, its interesting how the mechanics pull off big complicated repairs in a parking lot or on the side of the road.
I wouldn't be surprised at all if the snot rocket is getting technical and parts help from Ford engineers during the off season, that little tiny 5.0L is slaying the BBC boosted engines, he never seems to have any problem getting his car to hook on any track, defies logic. You built a super-fast amazing car.
Prize money? Lol I dont think anyone is doing this for prize money it might be like $1500 which would barely cover the cost of the hotel rooms for the week!
Thanks, and yes my definition of fun is definitely a little different. I like to challenge myself and I am constantly do things to do that both physically and mentally. Ironically when I got away from drag racing I got heavily into triathlons up to and including completing a full Ironman in 2015. I tell people all the time doing a full Ironman is easier than this shit. Definitely cheaper lol!! I always felt I could race a half ironman and for some reason I never finished a half that I was satisfied with and I've done 7 or 8 of them. In December 2020 I did my last tri a half ironman at the Daytona Motor Speedway which was cool as shit race with me riding my TT bike around the track. I was by far in the best shape of my life as I started training in fall of 2019 for a spring race thing was canceled in 2020 due to Covid except this race. I was crushing the race up till mile 25 on the bike when some asshole forced me into a cone and I went down hard on the bike. I actually still finished the race even though I was a bloody mess and the bike was trashed. I obviously didn't accomplish what I set out to do with that race and I came away from that thinking how much time it took to prepare for this race and how there was still other stuff in life I still wanted to do. In 2021 I bought my TSO car back and here we are today. I was a fit as f$#! 51 yo and now a fat and broke 55 yo who didn't finish Sick Week 2 years in a row!!
Bret LaSalla is on another level all together. He is really smart and methodical and has the best of the best in his corner. He is also a professional and has a mult-million dollar organization backing that car. His success with the coyote motor has me wanting to build one some day.
I am signed up for Street car shootout at Sick at the Rock in April. I can test Thurs and race is Fri/Saturday. I really need a few good days to finish sorting the car out and getting it in the 7s which I hoping to accomplish at Rockingham.
The sick week tracks are radial prepped and none of the big tires ever made a clean pass all week. Lasala’s car is super impressive for sure but the tracks suit him and his car.
No prize money for sick week. Class winners get a helmet and overall gets a guitar.
A lot of cars, including mine, struggled at SGMP. IMO they simply had to much glue on the track. The 1st day we were there it was awesome we made 4-5 hits on the car all in the mid to low 1.20's. Finished the day with a 1.22 and 5.22 1/8. The next day was a total shit show and we couldn't get down the track. Tech day was a washout then day 1 was no better than Sunday.
This pic shows the issue I was having and is the same issue the big tire cars have on a track with a lot of glue. If you look the rubber under the tire is wadded up on the track and under the tire. Once that happens if causes the tire to shake then spin a few feet out which is exactly what happened in this video.
More tire pressure may have helped this but the same tire same tune and same air pressure at Bradenton. This was an easy 1.28 with no chunks of glue and rubber under the tire. It still can probably use another pound of air pressure.
On day 1 Ray told me there was chunks of glue coming off the track when I pulled forward to stage the car. He said he never seen that before. I was one of the first AB Radial cars to go down the track that day.
So really Tom is the only guy who is making money, counting on everyone to join-in for "fun". I guess all the Youtubers blowing-up SM billet engines make money based on their viewer count which is good for them. I just doesn't make sense for 1 guy to rake-in all that $$ and offer nothing to everyone else, that bothers me and it seems like it should bother everyone who spends a lot of money to prepare these cars. Just my not-asked-for opinion.
Mike
Mike
I’m not sure how much money Tom Bailey makes off of it. We didn’t win anything and spent a ton but had more fun doing it than you would think is possible.
I dont do triathalons but I am an avid cyclist. My wife and I have a zillion road bikes, mountain bikes and a tandem in our garage. These days most of my riding is relegated to being on a Peloton. Hopefully get to change that this year.
Did you race at Sick at the Rock? Looked like your car in Tom Baileys videos
Yes that was me in the video's.
I had a great time and got to take home some of Tom Bailey's money too!
We went to test which is something we have not had the opportunity to do since the cam change and Sick Week.
We tested Thurs with a few shake down passes. I had some small issues we chased but it ended well with a full pass and 8.27 I think the video was in Baileys for Thursday.
Friday there wasn't any racing due to water on the track from the 2" of rain the night before. We did complete the drive. All and all it was a good event, they should do a Street car shootout at BG. I would at least have a class I could fit into lol! We enjoyed the cruise the weather was nice and with the new exhaust on the car it was SOOO much nicer to drive!
I got three hits on the car on Saturday a 5.19 a 5.15 and another 5.19. While the car is not yet where we want it to be we got a lot of good data and the car performed flawlessly. The first two passes are on Tom Bailey's video. This pic was the 5.15 pass.
All and all it was a great weekend the car came home in one piece and with a few trophies and prize money. We are still down on power from what the car ran in 2009/10 but we are working on it. We changed nothing in the motor or tune up from Sick Week but did make some updates to the front suspension brakes and a full over the axle exhaust which I will post up some info on next!
I made some changes to the front suspension which came out really well. I added new UCA from TRZ which cleared the passenger side exhaust much better. I also finally installed the Billet spindles I have had for awhile. They did work with the Wilwood brake kit I had so I broke down and got the new Strange EVO kit. I also added the front wheel speed sensor which I really like and has been useful in determining when/if left front tire comes up and I am using it to turn on and off the Gear vendor.
Saved a few some weight 9# a side to be exact and that was over the already lightweight Wilwood set up
Ray fabbed up a custom exhaust. We bought the material before Sick Week but ran out of time. It turned out fantastic!
While it has been a long road for sure we have made a lot of progress and looking back it hasn't been that long since we brought the car out for the first time in January 2024 for Sick Week. The punch list of of projects is running low and most of what is left is just cosmetic stuff I want to do. We are making some updates and changes with the data we got this weekend and planning to be at Bowling Green to test. I will be returning to HRDW in September looking to accomplish what we set out to do at the beginning of this thread which is a bonafide street driven 7 sec GN!
