building boost
buickruss
Unable to build more than 1 or 2 pounds of boost at the line. Hurts the 60' time. What are you guys with stock setups able to do? Im wondering if I have an exhaust leak
Russ
What kind of brakes you running and do you have a aftermarket stall?You can run some s-10 brake wheel cylinders to get some more boost on the line.What kind of tires where you trying to build boost on?
here ya go:
PTC converter and PT6776RH turbo. No header leaks!
Stock brakes.
MT275/60-15 in the rear
The week before I could get 5 PSI at the line. 60' time in the 1.8 range. No other changes and the car seems to run the same. only thing different is now I cant build as much boost
boost
if the car runs the same then maybe your boost gauge is kaput ..?
