Building up a TH-350, what parts to order
TwoLaneBlackTop
About done
I have really been considering this option and think it will be the direction I choose due to overall reliability at higher hp levels over the 200.
But what all should I buy to make a nice strong tran brake equiped TH-350.
Red When are you going to make your way down to Richmond one friday night?
They won't mind you'r a "tad " under 11.50 with no cage:D
ha ha ...Richmond boots me faster than vmp or MIR
I might come up with a customers GN b4 long and try it out ;)
First, ditch the factory spring & roller intermediate roller clutch. Replace it with a 36-element sprag assembly. That'll double your torque capacity while eleiminating the weakest point.
In switching from the 200-4R with its 2.78 low-gear ratio, you may benefit from the addition of a 2.75 low-gear set in the TH-350.
Beyond that, a good valve body, high quality frictions and a good transmission mount should get you going.
