Built 2004r By Jimmies Trans
jbaker
hey all,
trans is the original core from our 1985 monte ss which we bought new and still own, so its a one owner. the buildup was done in year 2000 by jimmy's transin mundulein,illinois. it has right at 10,000 street miles and no more than 100 strip runs. first 9000 miles and 90 strip runs it was behind a 350c.i.d./330h.p. gm crate motor. the rest of the time it was behind a 630 h.p./413c.i.d. both were carbed and no nitrous ever and no transbreak. last fall/winter we built a 787 h.p. small block, and chose to put a turbo 400 behind it. so out came the 2004-r.
the build includes a PTS EXTREME billet input shaft and a PTS EXTREME billet shafted forward drum. billet servo, level 10 shift kit,manual/automatic valve body setup, 700r4 bottom feed filter with pan spacer, the usual boost valve mods,seal retainer, extra clutch plates,h.d band,etc. .....i can forward to you the details that are included in jimmy's build.
the trans is solid and still works fine...fluid/filter changed three times since the buildup. last time was fall 2008...... fluid came out clean and red and no trash
can forward pics if needed.
$1000 ..... plus shipping
call 309-853-9671
or 309-853-7035
thx jeremy and jerome baker
jbaker@kresscarrier.com
