so whats the outcome here? glass is better than abs or oem is the best? also where can i get the full length rear filler from and where should I buy the other fillers from as well? I want to just install them, make sure they fit good and then take them off and send them along with the car to get painted. Let me know Thanks
As of right now, no one sells a one piece rear filler. The one in the picture above was glassed together from two pieces. If you want one that you can just take out of the box, paint, and screw on, I'd say get OEM. Hope this helps.
In short: There are pros and cons to both OEM and fiberglass.
Mike B.
what do you have to do to glass ones besides paint and screw on?
