Bunch of parts, Autometer, etc
FastRegalWE2
Wish I had another Buick!
These are most of the parts I was going to keep for my next GN but I dont think Im going to go as far with the next one as I did with the last one...
1 50lb injector.....$25 (only have 1)
2 83 lb injectors $30 each (have 2)
5" Monster tach with shift light, Sport Comp $125
2 5/8" ELECTRIC Fuel pressure gauge with sensor and wiring $150 (was over $200 new) Sport Comp (mounted in radio surround trim with delete plate)
2 5/8" EGT with pyrometer, probe and wiring $125 Pro Comp (mounted in radio surround trim with delete plate)
2" Electric trans temp with all hardware, NEW never installed $30 Sport Comp
3" Electric Water temp with all hardware $20 Sport Comp
Cometic HG's NEW $150
Hood shocks cylinders (Kirbans) $25 for the pair
ATR driveshaft loop $50
Chrome A/C Compressor cover (BuickGN.com) $20
Manual boost controll, locking style with under dash panel and vac lines $25
stock battery hold down $10
stock 200R4 detent $20
TPS tap harness for powering FAST system (Caspers) $30
2 gauge console gauge holder, grey, $15
2 pod a-pillar gauge holder grey $20
stock coil bracket $25
stock 3 leg alt bracket $25
Serial to USB adapter cable for FAST $10
push in vavle cover breather $5
rear upper axle housing bushings, black urethane NEW $15
stock fuel return line bolts to timing cover, I had the rubber removed and repalced with braided stainless, nice piece.... $40
Power Master mini starter $150, I installed it to adjust the spacing but never fired the motor with it (was about $200)
-8 AN fuel feed line, enough to run from the tank to the fuel rail with high pressure high flow anodized mesh filter (filter alone was almost $100) Worked fine on my car with 554RWHP -$75
stock injector harness $35
All parts are off and ready, pics upon request
Or will trade entire lot for a nice low mile 87 GN.... j/k :tongue:
need these please paypal address and shipping to 32025
I sent this on the other board....
Jeffery,
I'll take the fuel line, Console gauge holder, 2 guage a pilliar holder...
Let me know where to send payment and how much shipped to 08837.
so am I getting the console gauge holder/pod or not ?
if you compare the times on each of the post I was first
Ill take the stock 200-4R TV cable
I have a pic of it, will have to send it to you. Its held to the surround by 2 stainless screws because when I put the gauges in it kinda distorted. You wanting just the delete or the gaues installed in it as well?
payment sent for faskets, 2 gauges and plate please please ship with other stuff I ordered earlier
The following parts are SOLD (asloan)
Cometics
ATR driveshaft loop
radio delete plate with F/P and EGT gauges
