Does anyone know what the upper RPM limit is for the standard static two speed emissions test for California? I'm not in a dyno area. Idle and 2500 RPM.
The engine is fully stock with a new cat, O2 and working EGR so I don't expect any problems but I did make a chip that:
1. Raised the PE enable to 50%. It certainly doesn't take 50% TPS to bring it up to 2500 RPM.
2. Set the boost WG to 0% through 2800. Just minimizes boost.
3. Set the fans to 215 on and 210 off.
I want to run the idle as high as I can to keep the cat lit.
Anyone see a problem with the above?
Terry
Terry
