If you are going from stock heads to a ported and polished set that will give you a good power increase across the board. You should look at upgrading to 60pph injectors. The cam is not the power adder the turbo is. The addition of a good roller cam, lifters and correct springs will help with valve train stability at 6000 rpm. You will have a motor that pulls to redline as it should
