SignUp Now!I'm about to pull the TC for a double roller install. Is there a fact. cambutton in there? {original timiing gear} Do I need to install one? I have'nt seen any vendors listing them.Thanks
Make sure you don't run the stock tensioner, it will end up in your oil pan
HTH
Prasad
HTH
Prasad
Could you please explain this??
I just did a online price check at O'Reilly's- Melling CB100-$14.99.
where are you guys getting the aftermarket buttons? I want something other than the spring and plastic stock one.
and which are you using?
A.j.
A.j. The Melling (CB100) that I listed above is a rollerized cam buttom not plastic like the orginial, even the button that I got from the dealer was rollerized. What ever parts store that sells Melling automotive products; Napa, O'Reillys, Autozone, etc will be able get you one.
