- May 26, 2001
I have some one checking on a cam for me. I decided to do a little checking around my self. Here is the basics of what they ALL are telling me:
Cams are rough ground close to the "average" or "common" specs (not just the lobes but also the bearing journals). They are then heat treated to a depth around .060". The cams can / will warp during this process. Since they are rough ground fairly close and the heat treat goes 60 deep they are then able to true the cam up and finish grind it w/o going through the heat treat (therefore not breaking into the softer untreated metal).
Now the problem is I'm looking to get a cam thats around 220 @ .050" lift. This is a Pee-Wee cam compared to the average stage 2 headed application. The cam can not be ground that small w/o breaking through the heat treat. You can not take a old cam and grind it down and retreat it because you have no extra stock left in the journals to true the cam back up after the heat treat.
Comp cams told me they can do a cam based on a round lobe blank. This would be a multistep drawn out process and wont be cheap. They told me it would take 4 to 6 weeks to make the cam and it would cost around $800 for the cam.
Crane cams told me they could make me a custom hydraulic flat tappet for $204. With all the bad luck people have with flat tappet cams in these motors I don't know if I would feel comfortable trying to run one.
Any body else been through this?
Jason
This was edited due to the original thread title.
