Cam lift measured at pushrod
Gnx6
I am going to do some checks on my engine to decide if it is worthy of valve springs, some new gaskets and a timing set. I want to measure my stock cam to make sure it is not partially wiped out. If it is I may just do a fresh build instead but would rather keep this one alive.
What lift will I see at the push rods with the rocker shafts out? Intake and exhaust. Thanks!
.250"/.265". I would expect a little error going off the pushrods
Great, thanks Bison! I have done the left bank so far. Exhaust is 260 to 264 and intakes are 248 to 250. Need to pull heater pipe and hoses to get right rocker cover off. I have fancy covers so don't want to beat them up removing them.
