Cam Question !
2 QK 4 U
Banned
Q: Does this cam require a huge azz convertor?
Q: Will my stock convertor work with this?
Speed Pro/Sealed Power (Federal Mogul) part #CS-1016R
@.50 duration... 204 INT, 214 EXH
SAE duration..... 280 INT, 290 EXH
Cam Lift............ .280 INT, .290 EXH
Valve Lift........... .448 INT, .472 EXH
Lobe Centers.... 107 INT, 117 EXH
Lash.................. HYD
@.50 Cam Lift.... INT: 5- (BTC), 29 (ABC); EXH: 44 (BBC), 10- (ATC)
SAE J604............ INT: 28 (BTC), 72 (ABC); EXH: 77 (BBC), 33 (ATC)
No and No. Any cam will benefit from an increase in stall (over stock) even the stock cam. A 204/214 prolly needs a 2800 stall which is prolly the most common converter for a TR available from our network of TR vendors.
What would be the "standard" in convertors?
Are Red and Orange Stripe convertors good?
I have one of those cams for sale for $80 NEW if you still need one. Thanks,Frank
