Ok, so I got the engine to 25 degrees ATDC, took out the old cam sensor and am trying to install the new cam sensor. The gears will mesh but it seems like it's having an impossible time trying to drop into the oil pump drive. We've oiled the o-ring and gear.
I've tried moving it around a tooth at a time and while it feels like it drops in there is still a tiny gap inbetween the cam sensor body and the engine block.
I'm assuming once the sensor fully seats it should be flush with the block, right?
