3.8L V-8 eater
- Jul 22, 2006
I'm having multiple issues at the moment and do not know if they are related...
1st off the car is cranking longer than I would like before starting...Once started it idles fine, but once warmed up the BLM's are going to 160. Sometimes after it has been running for awhile it will sit there with a slight surge with the BLM's bouncing from 122 to 160 surging as the numbers change. For the most part BLM's are at 160 when not surging...
2nd issue....As I cruise the car runs nice and smooth BLM's around 126, but as I creep into boost it starts to hesitate slightly with any boost over 2lbs or so...
3rd issue...I unplugged the cam sensor with the car running and it died immediately. Not sputtering then shutting off; just shutting right off as if you were turning the key off...Should this happen?? I'm thinking this is a cam sensor issue..
Things I have done:
Switched to a different ECM
Changed spark plug wires
Tried multiple ignition modules and coil packs
Plugs do not looked fouled out; nice tan color
Tried to change out my 3.5 maf and try a 3" maf car would not stay running with the 3" maf???
Looked for vacuum leaks and cracked drivers side header; all appear ok...
Checked grounds can't find any that are loose or broken
Things I have done:
