Cam Sensor Rebuild Service
scot w.
GNSperformance.com
GNS Performance Turbo Regal Cam Sensor Rebuild Service
We are proud to announce that we are now rebuilding cam sensors for the 84-87 Buick Turbo Regal. Why buy a remanufactured cam sensor when you can save $100.00 and have us rebuild your old one back to new? Gary Tarwater & I spent a great deal of time at Richard Clark's place learning how to rebuild these "Properly" with the proper jig. So, you can rest assure your cam sensor will be better than if you were to buy a remanufactured one from a large parts store. At this time we do NOT replace or repair the cam sensor Caps.
NOTE: We will be in Bowling Green for the GS Nationals so we will not be able to rebuild them during that time. If you need one rebuilt before then you must get it to us before Oct. 12th.
PS: Please remove your cam sensor cap, we will not need it to rebuild your cam sensor!
Rebuild Cost: $80.00 - This includes the return shipping!
Rebuild Process:
  • We completely take it apart and clean it inside & out.
  • We clean the cam sensor gear.
  • We then balance the top reluctor ring, which was never done on OEM cam sensors. (Same as Richard Clark does)
  • We replace the two Bronze shaft bushings in the cam sensor body.
  • We clean the coked-up oil off the cam sensor shaft prior to re-installing.
  • We install a new wave-washer and shim-washer.
  • We clean the soft packing material under the reluctor ring, oil it and re-install.
  • We then install the shaft with a new roll pin so once we are done the internals are completely rebuilt with brand new parts.
  • The cam sensor is oiled during assembly and checked for proper clearance before it gets returned.
Parts Replaced:
  • Wave Washer
  • Shim Washers
  • 2- Bronze Bushings
  • Roll Pin
To get your cam sensor rebuilt simply send the cam sensor to us with $80.00 enclosed and it will be rebuilt and sent back within 4-6 business days.
Please send it in via US Postal Service to this address:
GNS Performance
PO Box 216
Dandridge, TN 37725
GNS
Management
